Finally did the update to v3.4 via USB. I questioned a Ford online support person about it not being available over WiFi. After holding quite a while they informed me it’s not available for download over WiFi at this time. Whether it’s truly this update or they are not using OTA updating basically. This is suppose to be a big feature in the ‘21s
Anyway I left the truck to go to sleep for a couple of hours. Sync never came back up after performing the update. Will check later.
For those of you that show your at a lower level of Sync online, then Your truck really is. You can select and Hit browse for the log file on the flash drive after you have completed the update. This will be on fordowner.com and the same page as where you performed the download from. So in the future you can truly see if an update is available, that you don’t have. See below
![38DAC1CB-C8C7-4DF3-A812-19A28BC672B3.jpeg 38DAC1CB-C8C7-4DF3-A812-19A28BC672B3.jpeg](https://www.fordraptorforum.com/data/attachments/137/137832-e6576107704324bce9d45d64348f9452.jpg)
