Sway bar removal pros and cons
bstoner59
does it come in shmedium?
Orange, CA
Hey i have a question, sway bar delete is recommended when you install 3.0 in the front?
---------- Post added at 10:33 AM ---------- Previous post was at 10:33 AM ----------
Please send some pics of the sway bar delete
The RPG truck has a sway bar on w 3.0's. Mine is setup the same w/out the sway. Honestly the difference isn't as much as with the stock shocks.
JDUB
Wildomar, CA
Now i want to find a way to make it work with out cutting the bed. I've been think ing about for a while now just was't sure how beneficial it would be hopefully some more will weight in on this.
Been contemplating this as well since I have removed my sway bar. Need the rear sway bar set up from the 2010's. I wonder if the 2010 rear sway bars would bolt directly on to newer Raptors? or at least bolt on with minor modifications?
pirate air
will plunder your booty
Say what? 2010s didn't come with a rear sway bar. None of them come with a rear sway bar.
Aaron
Meme Corps Commandant
WA
Yeah I was gonna say, if the 2010's came with a rear sway, I got friggin cheated! :wizserious:
JDUB
Wildomar, CA
My bad! I thought there was a rear sway bar on Tanner Foust Raptor...the one he took around the track in Germany? And I thought someone on here stated the 2010's had rear sway bars? or maybe they were supposed to have them and Ford X'd them?
---------- Post added at 10:24 AM ---------- Previous post was at 10:12 AM ----------
(They changed the sway bar in the front, and added one to the rear.. (i have confirmation on that) Now as far as the exact set up, pretty tight lipped. It is not hellwig set up or anything currently offered that I know of. Unconfirmed (trusted) source said that the Raptor was tested with rear sway bar. It was mounted to the bottom of upper shock mount. The hole for nutsert is still present at least in 2011 and 2012 Raptors that I have personally seen.)
-Greg (aka squatting dog)
Share
| Like
MotuMute likes this.
I know I wasn't going crazy!
Whole story here, below:
http://www.fordraptorforum.com/f83/...-assault-n%FCrburgring-ford-svt-raptor-21893/
Squatting Dog
Kansas City, MO
Don't listen to that guy!
