SVTCALI's audio build
The Car Stereo Company
here, on frf
from the looks of it, yes, but i am not sure about a ported box. im not sure there is enough airspace for a port. this specific woofer needs a port 9.35in2 by 10.5in long for maximum output. i just dont know if it will fit properly, but since i have my copy, i can try it out later.
Yukon Joe
Trafford, PA
Looks like a lot of work.
I'd be ok mounting the amp under a seat or behind the rear seat in the wall. Wait till you see a SCREW, there is a lot more room in there.
Joe
Maxx2893
Rock and Roll Offroad
Burleson, TX
Busa, what's the configuration so far? Is it 2 subs under the 2/3 side and amp mount elsewhere or 2 under the whole thing? Just curious. If possible I'd like to keep the 1/3 side for storage of tow ropes or other things.
here, on frf
for SVTCALI's build, its just 1 and an amp. but yes, for a dual woofer setup both woofers will fit under the 2/3's section and the amp will have to go somewhere else.
also, i used a rockford fosgate 500w amp instead of the JL 360/2 because of the location, it runs cooler and is smaller.
Maxx2893
Burleson, TX
For mine are we still think 2 pioneer 12's and a Rockford Fosgate D1200 or whatever?
here, on frf
800w amp. but yes. im probably going to go in on sunday to get the bulk of yours done. it would be nice to be able to port the box, so later this week i will be doing so mock ups of the configuration
Swagger4
whittier ca
Why not use Cotten in the box to help simulate a bigger box by slowing down the pressure waves. Right?
Boss Hoss
Colleyville, Texas
I used the Orca Black Hole tiles and filler---Focal owned or had something to do with this at one time but now I am not sure.
Blackhole / High Efficiency Dampening Products
Sometimes filler is needed other times it will hurt the sound. Am wondering a little about the Amp location. Seems to me that heat would be an issue located in the box.
