Yukon Joe
What's the consequence from the rubbing? It's not constant is it? Only at full lock and while aired down?
Yukon Joe
www.RUNRAPTORRUN.com
Yukon Joe
Yukon Joe
Run Raptor Run | Great Lakes Raptor Excursions (GLRE)
Here is the link to my install:The ReadyLift ucas that I installed do not rub with the stock wheel and tire setup. Take a look at my install thread. I will add a link when I get to a computer.
The ReadyLift UCAs are not adjustable. I don't see how the Icons could be adjustable with out removing them.I don't think readylift's are adjustable? Is ICON and SVC the only adjustable without removing UCA's out there?
I have them and have seen no issues with rubbing of any sort.I have heard that the ReadyLift product was designed to work with the stock rims but I have yet to confirm that.
http://www.fordraptorforum.com/f9/readylift-ucas-tie-rods-35633/
I would have to measure, but the closest point of contact to the tire / wheel is the uniball cup at any steering position.At the uniball, the ICON's do not rub either. I noticed in your write-up, you are looking at that distance (being .25"). How close is it on the arms with yours when you turn the wheel fully locked in either direction?
Ok, I hear over and over again if you are going to do spacers, get some good quality ones. I think I might of found from my search one of the better ones while I wait for SVC to see what they come up with. It is Rough Country. I've heard of it but never purchased anything. Is there something better out there or does this one look pretty darn good?
0.25-inch Wheel Spacers for 07-13 Chevy / GMC 1500 Pickup, Tahoe/Yukon, Suburban/Yukon XL [1065] | Rough Country Suspension Systems
The 1/4" spacer on stock wheels, with Goodyear Duratrac tires did not clear the uniball cup enough. I had rubbing on the cup during normal driving.
A narrower / less knobby sidewall tire might be OK with the 1/4" spacer.
I have SVC UCAs
so let me understand this. You just slip this over the wheel bolts and then mount on your wheel? Will you have issues with the wheel nut not grabbing enough thread?
---------- Post added at 10:12 AM ---------- Previous post was at 10:11 AM ----------
so you are running aftermarket wheels now?
That's correct.
The studs on the hub are long enough for a thin spacer. The issue is the hub centric wheel is now NOT using the hub to transfer forces. Everything will be through the studs. This is the main reason they are bad and can cause breaking issues.
However, I think @svc is making a hub centric spacer to address this issue.
Yukon Joe
