Stock Front Shock Removal
ExpeditionFatherhood
Danville ,CA
Remove those 3 nuts
---------- Post added at 07:16 AM ---------- Previous post was at 07:15 AM ----------
Hit them with a hammer and they will come loose
t_j
Chicago, IL
I got the upper shock mount nuts off. Thanks guys for confirming which ones needed to come off.
To disconnect the tie rod and UCA, should I just take a hammer to them? I removed the nuts already I just don't know how to break them loose and don't want to damage anything.
Hit the knuckle with a hammer you will need a heavy blow hammer and hit it quite hard until it breaks loose.
Huck
Chicago Sw Burbs
Take a hammer to the side of them. Not the bolt it self.
It will break the taper free and release.
If you take a hammer to the bolt, you may not get the nut back on.
t_j
Chicago, IL
I did say to the side of the knuckle!
Humvee21
Humvee21
Well, the 25" breaker bar worked to get at the lower shock bolt. But that thing bent so much I was worried it was gonna snap.
I'm still having trouble with the tie rod and UCA. I've taken a 4 lb dead blow hammer to it maybe 20-30 times and I still can't get it to budge... This thing is kicking my ass.
t_j
Chicago, IL
Time to switch to a club hammer, put some ear defenders on when you do it. Make sure you only hit the side of the knuckle directly surrounding the bolt, should only take a few good hits.
95,793
59,476
egermann
