JDUB
How are the fronts refilled with nitrogen? Do they have a shrader valve somewhere or other means? I can't find anything obvious...
O.K. All you SHOCK GOOROO'S! I have 41,350 miles on my 2011 SCREW. I bought a used set of 4 OEM shocks from a 2013 SCREW. 15,000 miles on them.
So I will be sending in the old ones once removed. If it goes as planned I have 25-30K before I need to get the work done. Start saving now!
BDRAG
Same OEM setup as the rears with the plastic BB covering the nitrogen needle insertion point. I've been told you can use a Schrader valve on the fronts but I haven't tested that out yet. I know my fronts need to be rebuilt so ill just have to try it out.
We sell a pretty inexpensive tool for these type of nitrogen fill points....here is a link to check it out
That good info, thanks for bringing it. Does this needle damage the port such that after some number of insertion, it leaks?
Do you know if this is usable on front and rear OEM Fox units?
From your website:
Tech Info:
• We recommend using extreme caution when using this tool
Not sure I got enough caution!
Sounds great. That is something this site has been needing for a while.To rebuild there are so many other tools that you need. Myself and Nitefighter hope to get a rebuild video for the rear shocks done soon.
