GEN 1 Steering Wheel Red Stripe Restoration
Augster
Augster
Sandy Eggo
It took a year for me before I finally did the replacement, even though I've had the kit sitting on the shelf all this time, so here's a follow up with before and after photos.
Starting with the completely worn-out stripe....
Peeking at the underside to see how the ends are finished....
The ratty old one, next to the new. I lined up the old over the new to punch holes in the same locations...
New one on and looking good! Watching his installation video, the Builtright owner referred to the Ford original stripe as "leather" and his replacement as "vinyl." If the replacement is indeed vinyl, I would be truly disappointed...
I just couldn't line up the ends perfectly and stop the ends from splaying outwards while man-handling this in the cab, no matter what I did. Prepunching the holes as he did in the video was useless because I couldn't clearly see the holes afterwards so I ended up blindly making new holes during installation. Oh well, at least it's not visible at all unless you're trying to purposedly inspect it from underneath. I intentionally rotated the joint further forward than the steering wheel leather wrap joint to further limit its visibility.
For future reference, don't punch holes too close to the edges or the vinyl (ugh) may rip when tightening the threads. And the OCD in me would probably pull the steering wheel off to do the install on the bench in order to perfectly line up and tuck in the ends cleanly.
WNCHSTR96
Athens, Alabama
I found turning the steering till the red strip is at the bottom made it SO much easier to sew. Unless you think removing the wheel is easier,
Augster
Augster
Sandy Eggo
Sometimes I may over think things but your idea sounds much simpler! But I hope not to have to do this again any time soon...
Augster
Augster
Sandy Eggo
