Starter Motor Bolts?
HAP
NE NC
Top bolt can be a bitch but with the right extensions and knuckles you can get to it pretty easily.
When my starter "failed" at havoc, I found one bolt missing and another one half way backed out.
freedommotorsports.us
Email: [email protected]
Would you connect the starter failure to the missing bolts?
Rookie
Fort Wayne, IN
No. At first we all thought it was a failed solenoid. Took it to the dealer because it was under warranty, they wouldn't cover it because there was mud under the truck. Ordered a starter myself and replaced it. Still didn't work. Started pulling relays and fuses and found the relay was bad. That incident contributed to my call sign. Lol
HAP
NE NC
Good for you. Your truck deserves to have all of its parts...
MTF
MTF
Celebration, Florida
FYI, if you run into the starter grinding, get it fixed right away don't wait to long like I did.
I only had it grind maybe 8 to 10 times in two months, all while remote starting so it grinded for a good 4 to 5 seconds, that starter must be strong.
It's been at the dealer for a week now. They replaced the two missing bolts earlier but the damage was done.
Getting new flywheel and starter, under warranty.
HAP
NE NC
So, do you think the grinding/damage was due to missing bolts?
Vincent
Same issue
I'm having the same problem with my 2013 Raptor. I thought it was the starter, but when I jump the solenoid it cranks and starts. I was thinking it might be a computer issue. Do you know exactly what relay was bad?
Rookie
Fort Wayne, IN
Not positive, you'll have to check the manual.
