Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
just took some pics. the stock pan slopes up at the rear. as long as the deep pan just goes deep at the center portion to follow the original pan and slopes up at the rear you should be ok.
If you are going to run it hard, run the starter wrap. Melted the solder out of the solenoid on mine running flat out across the Laguna Salida Lakebed outside of Mexicali, Baja. It can get hot down there and the clearance to the starter is not that much. Coated headers help too.
damn cherry read headers. my gramps use to light his cigarette of the old co-op tractor so yes it can get hot.
This interdicts what I said earlier but depending on how far out from the motor you are and how hard your running.
Nope. Didn't think of that. I'll look at those pics. I'm one of those kinds of guys that never open the instructions whenever I build anything. But I also have blonde hair so I am allowed to blame it on that.
Dough! I messed it up. The curved piece connects straight to the drivers header and curves under the trans.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
