How To Stainless Works Headers
Rookie
Rookie
Fort Wayne, IN
They should all be 1.25 I believe. The difference in model years was coarse vs regular.
That should be a good spot. The wood will help disperse the weight and keep anything from getting damaged. It's not good practice but without an engine lift you don't have many other options.
NickPic83
Rockland County NY
I used stage 8 bolts and I left them all out. When I got the header in position I put a couple of the lower ones in so I could hook the header on there to hold it
Rookie
Rookie
Fort Wayne, IN
I put the bottom ones in so I could set them on the bolts and they wouldn't fall out of position. If you have to, raise the engine up some more
