Stage 2 over heating while pulling
dillard09
College Station, TX and Socal
How do you get your coolant temps? Forscan? I have towed a couple thousand miles on stock tune with a FMIC. I keep an eye on the air temps, engine oil temp, and tranny temp, but don’t ever recall seeing a read out for the coolant temp that gives you numerical values.
I have a brand new SPD 170* tstat. I live in Montana, so I should have bought the 180 version instead. If you are interested, just pay shipping and it is yours. PM for details.
Yes you can add the numbers via Forscan. I also have an Ngauge where I can read it to.
Booth9999
Idyllwild
Mine is a 17; when it gets to 227ish the number spear above the gage, on 18+ it has it there from the factory.
I would love to have it if the thread starter passes.
1BAD454SSv2
HELL I ZONA
Like Gale Banks says the more you stack in front of the radiator the more velocity you need to keep everything happy. Especially Towing. IMO i think moving to a FMIC is detrimental in hot climates or mountain towing. Stock location IC are using wasted space with its own designated airflow . i would love to see comparison between a COBB FMIC and a cobb Stock location IC, i'm betting IC efficiency is only slightly better on FMIC. The FMIC is restricting more air that could be going to the radiator .
I would be towing on the stock tune at least and use lower gears in mountains and keep the boost from climbing . Garret and Cobb make nice stock location intercoolers.
