- Joined
- Jul 15, 2017
- Posts
- 1,224
- Reaction score
- 1,159
I just pulled up the listing in that link. The true Rigid SR-M Driving lights are definitely different than the Ford spec'd version that FP is advertising. Those are going to be lower powered than the ones from Rigid direct. Also, you would definitely need the kit for the true Rigid version because they have different mounting points than the ones from Ford.Just so I'm sure I'm understanding this all correctly, the SR-M Driving lights (SKU: 912313-0-21rpt-106) are NOT the same as the SR-M Driving lights (M-15200-RDL) listed here on Ford Performance's website that people have been using their Ford points to purchase, correct?
The ones in this FP listing show two bulbs, but are described as "SR-M Driving lights", but don't have the 3 bulbs that SPF's website or the pictures on this thread shows on these SR-M Driving lights. Or are they both "SR-M Driving lights" but the @Specialtyperformanceparts ones are a higher light output? And the SPV Parts SR-M Driving lights can't be installed without that entire kit that has the additional brackets and such, if I'm swapping them out for the existing inner lights? If they can be, what's the listing for just the lights themselves?
I don't want to mount a ton of lights to my truck, and I want to maintain the Rigid brand lights as I like the clean OEM look AND I swapped over a set of Rigid D-SS Pro Side Shooter Spot Light A-pillar lights from our Jeep, so I'm already ~$400 invested in Rigid. But I'd also like to get the most most light possible when replacing those inner fogs.
There isn't a huge difference in price between one pair of those Ford version lights and the kit for one pair of the true Rigid Driving version with the brackets and plug-and-play wiring. The Driving pattern is the brightest of all the SR-M lights, so it is more expensive than the Spot or the Flood, but all of them are immensely brighter than what comes stock in the OEM bumper.
Here is the link to the kit if you wanted to check it out.
SPV Parts 2021-2024 Ford F-150 Raptor & Bronco Raptor OEM Fog Light Upgrade Kit with Brackets & Rigid SR-M Direct Replacement Lights
NEW MODEL!! If you own a 2021 up Ford F-150 OR Bronco Raptor and you were excited about the included Rigid Fog kit, but were disappointed with the performance, you are not alone. Fits- 21+Raptor with OEM Fogs - ALL MODELS 22+ Bronco Raptor Rigid makes some of the BEST lights out there, but Ford...
specialtyperformanceparts.com
Please feel free to call or text me if I can help in any way or if you have any questions for me.
You can also use the code raptorforum100 at checkout to save some money on the kit.
Thanks!
Sidney @ SPV Parts
(317) 934-6778
