Springs and bumpstops
Madcowranch
Genetically Modified
OK
Is it different than every other shock? Generally you compress the coil until you can lift the cup up and off the lower rod end. Then there is a slit in the cup to slide it past the shaft and off the shock completely. Once the cup is off, the coil will slide off the bottom.
Thanks Dylan. I just wasn't compressing it far enough to expose the half moon retaining rings under the cup. Now my alignment spacers are frozen.:rage:
Madcowranch
OK
Why do you have to pull the coils off to ship them?
Because they weigh a shit ton. Not doing anything to the coils so no sense in sending them.
Those bottom spacers on the fronts were a bitch. PB Blaster is my friend now.
Ready to go in boxes.
pirate air
will plunder your booty
Oh. Just figured considering the circumstances; A, the shipping would be covered, and B, you wouldn't have to take anymore shit apart than you've already had to.
Huck
Chicago Sw Burbs
Shipping for the rear better be covered since it was installed incorrectly
