Spring differences 801 vs 802
ranger22
Tejas
I just picked up a 2024 802a in Avalanche. Parked it next to my 2018 Gen 2, this thing is easily 2” maybe closer to 2.5” taller than my old truck. I understand that suspensions will settle, but I was surprised by this big of a delta. It got me thinking, are there any differences between the springs on the 801 vs 802 of the same model year? I was under the impression that they would be the same.
taquitos
Seattle
No difference in springs. The 37 trucks have about 0.25” more preload on the springs than 35 trucks. The R is the only one with a different spring set up. It has stiffer springs up front.
ranger22
ranger22
Tejas
Ok, that was easy. Thank for you the prompt answer. I did search a bit before posting, perhaps my searching skills suck.
taquitos
Seattle
801 has 35in tires.
802 has 37in tires.
There is your difference.
I used to think the only difference between the two was the tire size before I started looking at part compatibility. If you put a 37 and 35 shock side by side you can see that the spring perch on the 37 shock is preloading the spring a little more. Then in the rear the part that connects the spring to the axle is different between the two. Doesn’t account for a whole lot of height on its own, but it’s not 100% tires that make it different. Ford could have kept the same amount of preload on both trucks and reduced unique SKUs at the expense of the 37 truck having a weird ratio of up to down travel, but they didn’t do that. I think it’s commendable that they did something to not have that ratio messed up for 37 trucks because realistically not many would have noticed.
Donmatteo
Santa Clarita / Coronado
OP was pointing out a 2in height difference. That’s what I was referring to. 35in tires vs 37in tires is the height difference.
GordoJay
Colorado
That's one inch of it. Bottom of the tire to the middle is 18.5" vs 17.5". I parked my gen 2 next to the gen 3 I'm picking up tomorrow and it looked like an inch difference, as expected. Some folks have reported gen 2 ride heights that are less than mine, and I have noticed that mine has settled in the rear due to the cheapskate leaf springs, so I'm not surprised that a low gen 2 would be 2" shorter than a new gen 3 with 37s.
