Speaker Upgrade
naamanf
If you are going through the trouble of modifying the A pillars, why not go all active and possibly upgrade to the three way system?
Also might want to take a look at the Helix DSP.
I second using the PAC AP4 interface.
naamanf
Why spend $250 on a PAC if you can turn the stock HU / ACM to a flat un- clipped signal with FORScan.
I did it because I just wanted to run a TOSLINK cable. And lazy.
I have heard mention that volume displays has been lost with the FORSCAN method, though I can neither confirm or deny
khahn73
Does this work without the Sony amp? I have the 801A sync3 system without a sub.
Sent from my SAMSUNG-SM-G935A using Tapatalk
Iceman6996
Baltimore
I want to upgrade my audio but the store I went to said that they don't have a PAC amp pro kit for the 2018 so you can bypass the b&o system signal processing. They do have it for the 2017 with they Sony system. But I was able to add a JL stealthbox to my system and that make a huge difference. Next I want to swap the all the door speakers and speakers. With either some focals or jls
lawdog
You probably know this, but I wouldn't until you know how you want to get around the B&O amp/processor and amp them properly...those will not sound like nearly what you paid for off the stock headunit/amp.
VegasRaptor18
No way to “bypass” the stock amp buy you can take the separate amp output signals and input them into a DSP. From there tune and send to your amps. A more involved setup but several here have done it including myself with great results. See my “2018 Sound System Upgrade” thread for wiring diagrams and more info.
Iceman6996
Baltimore
Your are right. I was also going to sound damped the door while I am doing it. Also I had the fake engine noise already cut off
Sent from my Pixel 2 XL using Tapatalk
