Why spend $250 on a PAC if you can turn the stock HU / ACM to a flat un- clipped signal with FORScan.
Does this work without the Sony amp? I have the 801A sync3 system without a sub.Why spend $250 on a PAC if you can turn the stock HU / ACM to a flat un- clipped signal with FORScan.
I want to upgrade my audio but the store I went to said that they don't have a PAC amp pro kit for the 2018 so you can bypass the b&o system signal processing. They do have it for the 2017 with they Sony system. But I was able to add a JL stealthbox to my system and that make a huge difference. Next I want to swap the all the door speakers and speakers. With either some focals or jls
Your are right. I was also going to sound damped the door while I am doing it. Also I had the fake engine noise already cut offYou probably know this, but I wouldn't until you know how you want to get around the B&O amp/processor and amp them properly...those will not sound like nearly what you paid for off the stock headunit/amp.
