SP542 Thread
smgilles
Most of mine were pre-gapped at 0.028, which is where I believe most people leave them. For those that weren’t, I adjusted to 0.028.
Same. Mine were all pre-gapped to 0.028 and I left them as such. The originals I took out at 15,000 miles were still gapped at 0.030 and looked Like normal carbon build up.
I changed mine out due to stuttering/hesitation when under a heavy load at ~80 mph. For example coming up an incline to enter the freeway and gasing it. I’ve had a few times where it would “cut out”, which I suspect was detonation.
Tried same scenario 3 times today in 80+ temps with high humidity and performed without issue after the plug change. Only time will tell.
I have a 2017 with Livernois 93 tune.
Gargamel
Banned
The moisture is causing this?
smgilles
No, I don't think moisture is causing this. I feel as if a knock sensor is attempting to retard the timing secondary to pinging or detonation in the engine. If correct I'd expect a colder plug to prevent detonation.
I may be off base, but $42 for 6 plugs and 10 minutes of time I am going to do some trial and error.
Sledgehammer
I hust wanted to thank the original poster for trying this! My truck has had a hesitation from day one. I finally got around to installing these plugs, made sure all were gaped at .028 and drove it. Big difference. No more hesitation under load and the idle is even smoother. I checked my stock plugs and they were gapped at .032. My truck has 8500 miles. Weird they were gapped that wide but either way truck runs great now. Thanks!
FORZDA 1
Gloucester, VA
I have the plugs on hand, but haven't installed them yet because my truck doesn't miss a beat, ever. If I have some type of problem that might be ignition, I'll try them then. Otherwise, I'm still a skeptic of "improvements" unless you're actually having a problem. If so, even a new set of stock plugs will likely help. Oh well, some day I'll pull mine...
FordPerf Addict
Does this do anything to the stock truck or only noticeable when tuned?
TXRaptor
I put mine in at the same time as my MPT tune, so I did not get a chance to see if there was a difference. My truck was not having hesitation issues before all the work and it runs fantastic afterwards. I figured for less than $50, it was worth it to avoid any problems.
