SnoBall Preparations?
Scrap man
Ohio
Dano6 I sent you a pm about that face plate or trim bracket for the remote head unit it looks great where can I get one call me if you could 740-346-5753. Thank you
Scrap man
Ohio
I figured it was something he had to make that was simple thank you shooter. Btw are you going to make it to our next event up here in Ohio or what we had a great time. And are you going to snowball.
Big Blue
Administrator
Staff member
Admin
USA
Snoball Prep Tip:
Required Item;
Ice Scraper/Snowbrush & -30 degree windshield washer fluid
For the folks coming from the south, if you only have water in your reservoir, you need to replace it with -30 washer fluid or it will freeze.
Handy Tip for all:
In addition to making sure my reservoir is filled with -30 before Snoball I also fill a small squirt bottle with -30 fluid. During bio breaks and stops, I give a few shots to my light bars to keep the ice from building up. LEDs give off no heat, so your off road lights will ice up. Peeing on them is only a short term solution, this works better.
Deleted member 12951
Guest
