Side vent lights
infinitereality
SLC IR/8
Louisiana
Just a heads up, I did alot of looking on ebay for perhaps a cheaper set of amber LEDs similar to the OP and came up empty so best bet is order from the link. :)
infinitereality
SLC IR/8
Louisiana
I'll be doing this after TRR. Had anyone wired them to the puddle lights? I'm looking as to where to tie in at.
Thanks,
Yukon Joe
Buffalo Run Support Raptor
RPG and WSI present The South Dakota Buffalo Run - FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor
Only down side to puddle lights is you'd have to get the wires inside the cab to do that. It's a purple wire, I can tell you that. Not really sure easiest path in there, possibly where I ran my cutout wire, it's close to door sill under carpet. Pretty easy to get to and run it up the door jam area to the mirror harness.
swoop1156
USA
Why would you only want them to come on when the door is unlocked and waiting to be open?
Yukon Joe
Trafford, PA
mprice1234
mprice1234
SVT Gen 1 Rules
Colorado Springs, CO
Upfitter
I'll be going with blue, so I'm not suppose to have them on when the lights are on.
But I see your point, it does limit the time they are on. I'll have to think about it.
Yukon Joe
If your not going to tie into the marker lights go with a upfitter switch that way you can control when they are on or off. Marker wires for the grill LED's are right in the corner of the hood by the drivers side vent makes for easy tie in. My two cents!
