Shock tech question
Jimster58
Greensboro, NC
Same reason they fill tires with nitrogen, its an inert gas that wont expand or contract with temperature.
It will try to expand with temperature increase in a closed system, which your tires pretty much are...the only result you will see is the pressure increasing on heating - the tires would otherwise balloon up in size if the volume wasn't fixed by the structural integrity of the tire. Nitrogen fills eliminate the oxygen (~21% in sea level air) which is CLAIMED to oxidize the inside of the tire and shorten its life. I've really not seen any evidence/documentation yet which substantiates that it's a benefit in any way.
xrocket21
Maine
It will try to expand with temperature increase in a closed system, which your tires pretty much are...the only result you will see is the pressure increasing on heating - the tires would otherwise balloon up in size if the volume wasn't fixed by the structural integrity of the tire. Nitrogen fills eliminate the oxygen (~21% in seal level air) which is CLAIMED to oxidize the inside of the tire and shorten its life. I've really not seen any evidence/documentation yet which substantiates that it's a benefit in any way.
Ive never heard it claim to cure oxidizing of the inside of tires, it is 100% for more stable pressures as the seasons vary
Staff online
96,364
60,273
NTXRaptor
