GEN 2 Setting TMPS value. Forscan or Dealer?
CptMorgan
Vancouver BC
I'm running the new 37 KO2 from the Gen3 truck now. They are much happier on and off hwy with lower pressure than I expected.
She's going in for service this week. Can the dealer change the TPMS value from 38 to 30 PSI?
If not, can someone confirm this is the correct Forscan code to modify: BCM module - 726-40-01 xxxx 1E1E xxxx ?
Thanks,
-Morgan
blwn
Florida
I don't believe the dealer has the ability with IDS to change it. Forscan can though and that code looks correct for 30psi front and rear
blwn
Florida
If you want you can also set IPC 720-04-01 and change the 4 to a C here xxCx xxxx xxxx and it will show the specified PSI in the Tire Pressure screen similar to:
