Service Engine Soon Warning after full PPF
V8 Goat
North Texas
Looks like my truck came wired incorrectly from factory then. I remember touching the inner lamp that had the cover and wondering why it was so hot, than realized the fog lights were on behind the black cover. Figured Ford or dealer put caps in wrong spot. I guess the PPF guys rewired correctly?! Can someone confirm if fog lights should come on with low beams in auto mode?
That's pretty funny!! It has to be that they did rewire it correctly.
The outer fogs will come on with the headlamps (low beams) if you have them turned on. Obviously you have the option to turn them on or off - depending on your selection, they will remain that way.
The outer fogs will turn off when the high beams come on, but the inner fogs will remain illuminated if you have them switched on.
