SDI E CLICK preview gen 3 (live valve tune)
SMIKE
Riverside CA
Finally available to order!
cscape
Earth
I see it’s for factory 35 trucks only. Is that due to differences in shocks or tire sizes? I’m assuming the former. I run 37s on my factory 35 truck.
Also, how does the payload adjustment work? Can you stiffen just the rear shocks?
NateMob
SATX
Correct on the former, you'll be hot to trot with your setup and eClik.
The payload setting helps the truck manage the set "payload amount" with the rest of the inputs being received to control movement. If the SDI brain knows you're carrying 500lbs of payload (50ish%) it knows it can expect that weight to cause compressions to hit harder and faster than an empty truck. Yes, you can independently soften or stiffen the front and/or rear shocks.
MNLeadfoot
MN
I'm curious on how different springs like eibachs would effect these, if at all?
