SDHQ Under Hood LED Light Install + Review
Squatting Dog
Kansas City, MO
Here is an alternate install not using sdhq mount and if you do not have lower led bar..
Just remove a torx screw on lower grill support, and use rigid light and mount... Wires up the same as sdhq kit and works great...
Since I have lower led bar also, it blocks 8 leds on the lower bar...
Round 3
-Greg (aka squatting dog)
Squatting Dog
Kansas City, MO
Option 3 that works with both upper and lower grill led bars...
Drilled a 1/4 inch hole in grill support bracket.. And mounted rigid light and bracket on passenger inside bracket.. This time the wiring harness connects to last led clearance light and extra wires are neatly tucked away along grill support...
Labraptor
Illinois
Thanks for posting about the upper light bar. I didn't even think about that one. Probably should have since I have the 30" in my truck. You saved me one head slap moment.
Sent from my ASUS Transformer Pad TF700T using Tapatalk 2
Squatting Dog
Kansas City, MO
It is a great product and idea.. The wiring harness is great, plug and play.. And the quality of it is top notch (heat shrinked, wrapped in nylon covering, and perfect)..
Maybe SDHQ can add the option with or without bracket for those with led bars, ant lower cost or something...
Madcowranch
Genetically Modified
OK
Greg you got more shit stuck to your truck than I can shake a stick at.
