SDHQ Under Hood LED Light Install + Review
BIRDMAN
BIRDMAN
Birdministrator
Boston
Ok fellss... finally figured outwhy this kept lowing fuses (#30 15amp fyi). The way they spliced this together is really funny (ok not really since this isn't cheap and I wasted time trying to figure it out). They used metal splices and then shrinkwrapped them all together.... can you say SHORT CIRCUIT. View attachment 19102
Yup that would explain it! Weird, I'm sure it was a fluke because mine appear to be shrink wrapped separately
Java
MI
I did this with a mercury switch a ways back. Much cheaper than the SDHQ kit.
f150corey
How about providing some info on you accomplished this feat.
seams easy.... find old Honeywell round mercury thermostat. cut the mercury switch out. wire power from the truck to it. hang it so when the hood opens it makes connection and sends power to LED's mounted where ever you want to put them.... boom :lol2:
Java
MI
mercury switch by sonicelectronix.com and roundeyes.com adhesive mini light grab the power from the battery. Screw mercury switch into hood lift.
Java
MI
loom up for protection. It looks like roundeyes may no longer have that adhesive LED, but I'm sure there are others available.
xtcbct
CT
Just installed this hood light mount from SDHQ. Works great and its really bright. At first I thought the light was a little big for under the hood. But when I popped the hood, I realized how much room there was. It almost looks OEM. If you turn it on while you drive, you will have a whitish glow behind the grille. Looks sorta cool but provides no real purpose.
Sitdown
Suburbia, IL
Great idea on the mercury switches!
I planned to do the budget version someone else posted, but realizing I would have turned that into a 4hr project that I would keep putting off until a day too late... So I ordered this kit last week. A true 5 minute install, great product and helpful pics from birdman.
