TAZMAN
Let me know how these new tunes work out. I have had the same issue for approx. 6 months and pulled the performance tune back out do to the shift cycling. Kinda gave up on getting it resolved.
As it's been explained to me, in a tune, you can up the line pressure in the transmission. When you up the line pressure, you are putting a little more stress on the tranny. Upping this line pressure is what causes the firmer, and usually, faster shifting, though.
LSUstang05 said:I had my tuner change my transmission tune to be very similar to the Tow/Haul mode in the stock configuration. I said that I wanted a faster kick down when I pushed on the pedal, but I didn't want it to hold gear like the Tow/Haul mode. He delivered exactly what I asked and I'm in love with it. My truck doesn't hunt for gears and it daily drives like stock, which is perfect since 99% of my time is on the road (just like the majority of Raptor owners). In fact, on the trip to TRR from Houston, I averaged 13.0-13.5mpg at 75-85mph whereas everybody else in the convoy was averaging under 12.5mpg. When I mash it, though, it runs like an animal and I'm very pleased.
I'm not telling you to go with my tuner (he is very good, IMO), but since you've already paid Mike, maybe ask him about something like I have.
SCT x3 93 Performance tune 2+ years ---Not a problem. Gas mileage SUCKS and I love it!
I do lock out 6th gear when i am driving in the city. I think the truck hunts for the highest gear possible.
lock her down and let it eat....lol
Agreed. The increased transmission pressures may increase the holding force of the clutch at lockup, but I doubt that unintended slippage would ever be a reasonable problem even at factory pressures. One thing to consider is that our transmission's TCC control solenoid isn't just an on/off solenoid, it's a duty cycle solenoid to promote a plush TCC lockup. If the TCC control solenoid duty cycle isn't working in sync with the fluid pressures, I suspect one could experience premature wear on the TCC clutch.
What I actually asked is if you've noticed the TCC lock in 5th gear when you have 6th gear locked out. Because the TCC is controlled by an electronic solenoid, I wasn't sure if the vehicle will lock it in only 6th gear or if it'd lock it in any gear/speed if turbine and impeller speeds were close to the same.
And all this in English means....
