S&B Filters Intake
2008fx4
Tucson, AZ
S&B Filters​ sent me my intake system for the 6.2L Ford F150 in speedy fashion gettiing it to me on its release date Monday. However, due to a packaging snafu, there was a piece missing. They sent it out next day air, and I had the piece in my hands before 10 am Tuesday. Got it all installed, have yet to have any true driving impressions. Very clean install.
Stock intake system – large box with the 6.2 logo on it is a massive chamber to help with resonance and keep the sound down with the stock intake. This is taken completely off, and all the tubing is replaced. The bottom of the stock airbox is used, but a new inlet tube from the fender side of the box is supplied, providing more flow. I am very impressed with the kit. I've ran several of their intakes in the past - 2008 f250 6.4L and a 2011 Jeep Wrangler, and won't run anything else.
Kevin
Looks good! I like the clear plastic to see the filter. Looks clean and not cheesy.
Scrap man
Ohio
I just installed mine today very nice fit and finish very close if you have a upgraded power steering resi but other then that I think it went together very well and the instructions were very impressive good pics well written much better then most
MTF
Celebration, Florida
Looks good!
I curious to see what will happen after a few thousand miles with the fresh air PVC hose.
Seems to be closer to the TB than the Airraid intake system which is sucking in spent oil vapors into the TB
I would keep an eye on that, could be you may need a catch can on that side too now.
Floyd91
Where is everyone ordering these from? I'm assuming it will work on the '10 without issue?
AbnMP13
Mississippi
@Rookie, can you get these?
2014 Terrain SuperCrew
Vortex Mud Guards ~ Husky Floor Liners ~ Rigid Dually Flushmounts ~ Rigid Dually Clear & Amber Fogs ~ Recon Smoked Mirror Lights ~ Bakflip FiberMax & BakBox ~ SVC Tune ~ Rigid 20" E2 Series - Combo ~ Mid Perch ~ Underhood & Bedlights by Noah
Ruger
Northern Nevada
With the factory resonator removed (if that's what it's called), how does it sound? Can you hear any intake honk, particularly at the shift points?
Floyd91
Talked with S&B today just to clarify that SKU# 75-5077 will indeed work with the '10 6.2.
