m3dragon
There is no tune needed for the intake.
Also if you plan on offroading a lot I would get the paper filter as it offers better filtration. The cloth one is more street use only. I have tested both and even S&B will tell you this.
Also this intake does not fit correctly if you install the PSS reservoir as a note. You would have to modify the reservoir to push it down as it sits taller than stock and pushes this intake into the hood.
