RPG Stage 2 and WSI HD Springs Issue
  • Start date
IRONMAN
Well-Known Member
MICHIGAN
Nope. The bottom of the clamp has a bolt in the middle on the bottom that goes into the springs. Didn't you win one of these like 2 weeks ago?
Sure did, just didn't run outside to check that.
Looking at the top of your pic doesn't show a bolt.
MajorAR
Kansas
Interesting. Went out to my black beauty to check my National SD springs and RPG stage 4+ kit.
I'm getting very slight spring strikes on the bolts for the frame supports. Though we drive extremely hard out in the desert. Bumps are in great condition. See pics.
treypal
Lord of the Raptors
Riviera TX
Folding the clamp won't hurt anything. The springs still have the u bolts and the front 2 clamps to hold the pack in line.
---------- Post added at 09:36 PM ---------- Previous post was at 09:35 PM ----------
If you notice there isn't spring clamps on the back of the nationals.
Madcowranch
Genetically Modified
OK
What pressure you guys running on your bumps?
---------- Post added at 09:39 PM ---------- Previous post was at 09:38 PM ----------
The backs of my Nationals have spring clamps.
Guest
Your back end is way too clean, I am jealous.
---------- Post added at 09:45 PM ---------- Previous post was at 09:44 PM ----------
Again, how to you check this?
Madcowranch
OK
Here's where mine has made contact in the past...
Huck
Chicago Sw Burbs
get the correct gauge first then its a schrader valve. If you use just a regular tire gauge you will loose everything in the bump by the time you get an accurate reading.
They come at 200 psi from fox.
MajorAR
Kansas
I keep it sand blasted clean. Very little mud in SoCal.
---------- Post added at 02:55 AM ---------- Previous post was at 02:52 AM ----------
Use one of these to check and adjust shock pressure.
