RPG Bolt on LT Kit
RPG
Orange County
We call this our BOLT kit. The web site is currently getting updated..
The kit is truly Bolt on.
We have had a few guys want more droop travel then the dual Shock Kit so I simply increased the track width to increase droop.. If you want to add the secondary Fox 3.0 External Bypass, you simply add the same shock bracket as our Stock width Dual Shock Setup.
We are still using the same +2" Glassworks Fenders with Liners.. So you don't need to change your fenders...
We don't want any more compression travel.. If we were to increase compression travel, that just means that the skid plate would go farther into the dirt... This yields more dirt over the hood = Ouch
We are installing this kit and still utilizing the Fox 3.0 IBP Coil Over. Down the road, we are going to install the Secondary Shock..
canamds450
Interesting info
Hey what is the full extended eyelet to eyelet lenght of the suspension needed for this kit?
RPG
Orange County
Interesting info
Fox 3.0 that we use on all of our kits.
This is a VERY Simple Bolt On Kit that utilizes 3.0's that a customer has already upgraded to. It doesn't require you to install the secondary shock.
canamds450
To late for me to know that
This is what i got after braking my head thinking how to do a propper install, but i think day by day i m getting there.
Too bad my hurry got me, but your kit is grate. congrats
Keep your hardwork going
RPG
Orange County
The Upper Control Arm Mount / Coil buck requires NO Modifications
