RPG Bolt on LT Kit
pat'sRAPTOR
Everywhere
You gain the travel when it droops. You're also gaining a little bit of up travel as well but we wanted to keep that to a minimum so you didn't have to go rearranging everything under the hood like moving the widow washer fluid reservoir or your battery tray and intake box we wanted It to be as simple as possible while still gaining travel. Hopefully Corey will chime in on the actual numbers cause I can't remember them of the top of my head! But this is one of the only LT kits that we know if thanks 99% bolt on the only thing that needs to be welded on is the secondary shock upper mount and that's very simple to do
---------- Post added at 06:09 AM ---------- Previous post was at 06:05 AM ----------
I'd love to see some closer pics of how the UCAs are mounted on there. Does the coil bucket need to be cut at all?
Here is a better pic from John Hammond's truck we did before TRR
canamds450
I could make a larger UCA for my hnm lts kit, it that is the case of using stock mount. That would not chance geometry if you make uca at it is 3+ +1" forward.
oxfordraptor
IIRC, it was 14" or 17" of travel but I could be wrong.
pat'sRAPTOR
Everywhere
This kit gets 14.5" of travel just got do r talking to Corey about it! This is our bolt on long travel kit. Our more elaborate LT kit takes some fabricating but is insane!
