Rogue Racing stage 4
ntm
Alberta, Canada
no i stayed with the stock colors, the upcharge to change was more than i wanted to spend.
---------- Post added at 01:00 AM ---------- Previous post was at 12:52 AM ----------
yes it is but.....
I wanted this truck to be a daily driver, and the few folks I've talked to that have the long travel kits don't like the on road manners after the conversion. I also had just spent a ton of cash at the body shop when i had the Boatec fenders and 37's installed. I had no intentions at the time to redo the suspension after spending a ton of money on the ADD stuff, and i sure didn't want to add more body shop time with bigger fenders. This should give me the performance i want without the long travel issues associated with it. Yes its expensive but if you want quality stuff that's engineered correctly.....
True enough, the install on the bolt on rogue stuff should be cheaper at least.
I'm very interested to hear about your experiences with the cantilever, I've been very tempted, but I keep hearing about longevity issues with larger shocks in a horizontal layout. Your first hand experience with the kit will be invaluable, as that trumps speculation...
jlatigo
jlatigo
Spring
Looks like they are well underway to getting it all assembled ...... now i'm getting excited!
jlatigo
jlatigo
Spring
seeing it installed is vastly different that seeing the parts just laying on a table! ...... damn that's a SEXY set up!
Idleone
Austin Texas
$25759.87
So this is the price out the door installed, correct?
---------- Post added at 01:30 PM ---------- Previous post was at 01:28 PM ----------
Please post your questions I will try and answer them as I can.
Thanks!
Ryan
Little off topic, but what other services do you offer? I want this kit so bad and would like to see what else you offer if Im going to have to make a trip to NV. Really just looking for an ARE top and fenders painted and installed. Can you confirm the above price is a good ballpark for pricing depending on options here and there?
---------- Post added at 01:31 PM ---------- Previous post was at 01:30 PM ----------
If you drive home through central TX I would love to take a look at this...
Deleted member 12951
Guest
Pretty sure that $25k figure is just for the hardware and does not include install labor.....
