Rogue Racing Stage 16 2015 F150 4x4
Rogue Racing
We are looking to move on to new projects and are putting our Stage 16 2015 F150 XLT 4x4 up for sale!
2015 Ford F150 XLT SuperCrew 4x4 6.5' bed
5.0 V8
VIN- 1FTEW1EF9FKE64988
7,233.5 miles
Twin panel moon-roof
Front captains chairs with center console
Black sport-cloth interior
7" touch screen
Modification list:
STAGE 16 SUSPENSION CONVERSION
THE BEST JUST GOT BETTER
Rogue Racing set out to make a lasting impression by creating the most sought after suspension upgrades for the 2010-2014 Ford Raptor that were able to still be daily driven while dominating the trails. Fast forward 3 years and the release of the 2015 Ford F-150, a great platform for improvements but 1 minor detail was missing..."Raptor". Ford left everyone including potential and current Ford Raptor owners in limbo waiting to know if the program was dead or was there something in the works?
Rogue Racing stepped in and created 2 amazing suspension conversion kits to satisfy every ones desire for off road performance, mean looks and fill the void Ford created.
We are proud to announce our latest offering for the 2015 Ford F-150 4WD & 2016 Ford F150 4WD. Stage 16 Suspension system, a perfect compliment to our subtle "Raptor" conversion (Stage 12) and our extreme performance (Stage 18). Taking the best of both worlds and making a middle of the road conversion that puts you ahead of the curve on and off road.
Front Suspension Features
Horizontal Uniball Upper Control Arms
7/8" FK JMX Heims
1" FK WSSXT Uni-balls
Double Pocket Lower Control Arm
1.5" FK WSSXT Uni-Balls
Flutted Bushing Mount
Double Shear Tie Rods
7075 Aluminum
7000 Series Aluminum Alloys Are The Strongest Made
7/8" JMXT Heims At Spindle
Stainless Steel Heat Treated Clevis At Steering Rack
Mil Spec Hardened Steering Rack Bolt
Coilover Shock Tower - Relocated Outside Upper Control Arm
Holds King 2.5 Coilovers w/ Remote Reservoir & Dampening Adjuster
Bypass Shock
KING 3.0 2 Tube Bypass Shocks
Located In OEM Coilover Location
Correct Length Half Shafts
+3.5" Heavy Duty CV Shafts
Limit Straps
2" Rogue Racing 4 Ply Adjustable Limit Straps
Front Suspension Options
Slot Delete Alignment Kit
Allows For Precision Alignment via Upper Control Arms
Keeps Lower Control Arm "Centered" In Crossmember
Front Lower Cross Member w/ Bump Stop Cans
3x Stronger Than The OEM Crossmember
Integrated Bump Stops For Additional Suspension Dampening
Supports KING 2.5 Air Bump Stops
3/16" Laser Cut
CAD Designed
Cutting & Welding Required
XRP Brake Lines
Minimal Volumetric Expansion Under Hard Braking Situations
Rear Suspension Features
3 Piece Bolt On Bed Cage w/ Bump Stop Cans & Frame Gusset Supports
No More Bent Frames
Prevents Bottom Out Feeling
Weld On Shock Mounts at Rear Housing
Leaf Perch Relocation Brackets
Increases Suspension Cycling
Leaf Spring Shackles
Deaver Sprung Under Leaf Pack
Limit Straps
KING 3.5 Bypass w/ 3 Tube Piggyback Reservoir Shock Absorbers
KING 2.5 Bump Stops
Rear Suspension Options
Currie Full Floating Rear End
XRP Brake Lines
Included Accessories
Rogue Racing Single or Double In Bed Spare Tire Mount
Tailgate Bed Support Brackets
2 Piece Intercooler & Custom Reservoir Tank
included Performance Add Ons
Whipple Supercharge w/ Shelby performance tuning 750hp. 620hp @ Rear Wheels (estimate)
Stainless Works Full LengthHeaders
Stainless Works Exhaust w/ High Flow Cats
Appearance Package
Fiberwerx Front Fenders & Rear Bedsides
Rogue Racing Headlight Support Gussets
Rogue Racing Bedside Support Gussets
Rogue Racing Modular 3 Piece Enforcer Front Bumper (Required Frame Horn Chop)
Rogue Racing Dovetail Rear bumper w/ Integrated Hitch (Requires OEM Hitch Removal)
Application Fitment Notes
37" x 12.50" MAX Tire Size
+18 MAX Offset On 9" Wide Wheels (Verify All Fitment Before Mounting Tires)
Rogue Racing
Rogue Racing
upscrazy8
tennessee
Same Truck? If so. Awesome build and #Bajaapproved GLWS
Rogue Racing
Rogue Racing
Bump!
Our F150 needs a new home so we can move on to new projects! Don't pay the "market adjustment" on a 17 Raptor when you can buy the Raptor killer instead!
