Rogue Racing NEW cantilever and J Arm setup
RLTW
TX
You want kings, gold.
Rogue Racing
Does that retain the factory coil over bucket by pushing the upper shock mounting points outboard ? 2wd ? The hydro formed rails that run from the cab to the radiator support have to go away I presume ?
Yes the front is all bolt on.
The back just the shackle hangers have to be cut off.
4x4
Rogue Racing
Don't be like that ! :specialed: I'm guessing baby links. Can't figure out the lateral axle control though, I certainly wouldn't trust it to the j arm assembly. The front must have some serious, tire through the hood, up travel. 18" is technically impossible without going +3.5" on the cv shaft/lca, or making a bunch more up travel. The lower droop limit is set in stone by the cv's angle. Unless it's 2wd, then it won't matter of course.
The front J Arm looks deceiving in the picture. You cant see the cross brace that runs behind the radiator.
Staff online
96,553
60,525
solozero
