iSurvive
Does anyone have a write-up on mounting the 50" roof mount?
I don't have a write-up but did install one last summer on a friends truck. We used the N-Fab bracket which is now the same as the one Rigid sells, with this type of bracket you will have to drill holes through your roof to secure the mount with nuts and bolts, we also drilled holes for the wires to pass through the roof for a clean install. Rigid use to have a black wire on one side and a Red wire on the other side of the light, now they have changed to smaller wires on one side only. What bracket do you plan on using?
If you have any questions fire away
Please give us a call and we would be more then happy to help you threw it and answer any questions or concerns that you have. Thanks
480-655-0100
