Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
To me its not an issue getting it repaired its just the principle of these things taking on moisture so frequently. Theyll fix it no problem. Just a nuisance.
Turn your bar on for 10 minutes or so to see if it dries up, it may never return. If it does return or if it doesn't work, contact Damon at Rigid, he'll get you set up
Sometimes the seal around the light gets torn during installation of the lense, thats what happened to one of mine, what I did was take off the glass and put gasket maker around the edges and sealed it back up. Even with hurricane Sandy its clear, wish I could say the same about my third brake light and tail lights. I'm sure Rigid will fix you up if you contact them though.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
