Reverse light wiring
DynoDynge
Zavalla, TX
Thanks Dyno. So, dual sources (power from reverse lights and from aux switch) connected to the same tap?
Yes, it is isolated by the relay & prevents back feeding into the other circuit
---------- Post added at 09:11 PM ---------- Previous post was at 09:08 PM ----------
Dyno, where did you might your aux switch?
3m taped to the side of the trailer receptacle. Flat black & not even noticeable unless you know it's there. Go2Marine has the switches in stock
The Car Stereo Company
here, on frf
that is a reverse polarity 5 wire system. not quite what you would want to use in this situation.
i would use a spdt relay. that way the normally closed circuit can be on a switch and then the reverse lights can activate the relay as backup lights. that way it also eliminates the need for a diode.
dataustin
You do know I was trying to be funny.... It has been a while since my last electronics class....are diodes wattage rated?
---------- Post added at 11:25 AM ---------- Previous post was at 11:21 AM ----------
Please disregard that last question...
badmonkey
Western Suburbs of Chicago
Old thread, I know, but I have a question for Noah or anyone else with the info. Where does the trailer receptacle get its +12v from. I'm not getting power to the orange wire, which is labeled +12v. Is this supposed to be a constant 12v or switched? In the owners manual, it says it gets power from relay #9, but where is it fused? And what switches the relay? I'm trying to connect my reverse lights to a switch and I don't want to have to run power all the way back to the trailer wiring, where I'm working.
