** RETROFIT HEADLIGHTS **-Custom built HID Retrofit pics and pricing
iSurvive
Highlands Ranch, CO
Sorry if this question is a stretch for this thread. Is it possible to hook up a light to two different switches, say one on/off switch and one momentary, or one on/off switch and one flasher?
I can see running two positive wires to the light, one from each switch. But would current flow back up the second wire to its switch and cause a problem? What would happen if you accidentally turned on both switches?
scarrjack
The Park, Alberta
What are the amp's for the off-road lights? I believe these would get hooked up to an upfitter switch as well, correct? What gauge wire would be needed for this? (12 gauge?)
I am really digging the look of the inner amber evil eyes, outer white angel eyes, off-road lights, raptor claw mark side marker, matte black stealth look and the sequential turn signals. Is this set-up a level 4?
Any sales coming up??
IRONMAN
Well-Known Member
MICHIGAN
I've known people to hook up there reverse lights to a separate switch so they could turn them on whenever.
Not sure if it'll feed back but I don't think so.
Yes your off road lights usually gets connected to up-fitter switch 3 15 amps.
Been running mine on there for over a year now and it's worked great, I had someone hook it up to up-fitter #4 and it blew the fuse right away cause they forgot to swap it out to a 15. I'm sure you could use 20 amps no problem either.
12 gauge is plenty good. and would recommend it.
Wilson's built is a Level 4 plus.
Do you do custom side marker designs/logos? Like maybe a sports team logo?
I can have custom made designs for the side makers but it all depends how detailed it is.
My guys vinyl cutter can only cut so small.
Wilson
South Dakota
the side marker is defiantly a finishing touch. It's not something your going to notice first but when you do it's like holy crap that's cool.
iSurvive
Highlands Ranch, CO
In my 2012 Raptor, switch 3 and 4 have smaller fuses (not an issue if you swap them), but they also have thinner gauge wire.
I had my Rigid 40" running on Switch #4 for months, but occasionally had issues with the entire bar not lighting up. One day I checked under the hood where the pass-thru wires connect and the wire for the 40" burned my fingers when I touched it. I moved it to Switch #1 and fixed the issue completely.
Switch #4 now runs a Rigid SR 20" and 2 Vision X HIDs with no issues.
I'm sure you can run Roger's lights with switch 3 or 4. Save 1 and 2 for something bigger.
scarrjack
The Park, Alberta
I have 3 things I want to hook up to upfitter switches: (1) the off-road lights on my new RSiWORKS headlights (that I haven't ordered...yet), (2)the halo's, and (3) I also have the Oracle side mirror LED's to hook up. All of them are fairly low amps but I need to hook one of them up to switch 2 I guess.
Maybe halo's to switch 4, off-road lights to switch 3 and side mirror lights to switch 2...
IRONMAN
Well-Known Member
MICHIGAN
You should be able to hook up the Off road lights of the headlights to switch 2 but just change out the fuse to something smaller.
Wilson
South Dakota
all my switches are now full I have 1. RSiworks off road light's 2. ridged fog's 3. halos 4. my little blue grill lights.
scarrjack
The Park, Alberta
When I got the truck a month ago I saw the switches and thought they look cool but I probably won't use them all up, 3 out of 4 will be spoken for pretty quick, lol. I am going to go broke accessorizing this truck. Totally worth it though.
Ironman, I should switch out the fuse in #2 from a 30 amp to a 15?
