B E N
You will need a set of sockets, torx bits, plastic panel removal tool, diagonal cut pliers, and hog ring pliers/rings.
Step 1 remove the seats, there are 2 bolt covers, 4 bolts and the electrical connections.
Use an interior trim tool to remove the bolt covers.
Use a 6 point socket and ratchet for the bolts, I think they are 17mm but I don't remember for sure
Under the front of the seat there are 2 electrical connections, they are easy to get to once the seat bolts are out. The grey levers just lift forward and the connection will seperate easily.
Remove the seat, take it somewhere easy to work on that is clean, I used my dining room. This is a great time to vacuum your truck out.
Remove the head rest. Along with the normal height adjustment button there is this sort of hidden button, push it in and the rest will slide right out.
Start disassembly with the seat back, Unzip the zippers on the side. On the bottom back side of the seat back there is this clip, you simply pull it away separating the front and rear upholstery, it takes some hand strength.
