Removing Plasti-Dip From Grill
The Macf
Vegas
You did the whole truck? Thinking about the roof and hood in black when I get home.
infinitereality
infinitereality
SLC IR/8
Louisiana
Yep I'm in process of doing whole truck. Been thinking about it since I dipped by bike couple years ago.
It's HOT here in Louisiana. Dip dries quick too.
Someone on forum did his roof black, said it took him 4 cans. Just make sure you remove tape immediately after last coat.
MichaelChad
Try adding 10-15% mineral spirits if you're not spraying in temp controlled room. Over 80 degrees and you won't have time to get the entire panel wet, high likelihood you'll end up with lines.
4 cans is a hell of a coat for a roof! Will be very very durable, and peel easy. For reference we usually use 5-6 gallons on a full size crew cab. You can do less with the darker colors but removal will be a bitch!
