Interesting video for anyone with 15 minutes to spare. Probably the most insight I’ve seen on the two types of rope.
@smurfslayer I’m sure that’s enough to make you stain your pants a little bit.. This happened more when I was still back East - CT/NY - but I’d always have to reattach the pull point that the other person “secured” to. Amazing how basic of a concept it is, yet still flys right over peoples head.
You have to use standard metrics when using that equation. Force in Newton’s = mass in kg times acceleration in meters per second squared (not velocity).not necessarily. figure a 7000 pound truck moving at 20mph maybe? once that strap starts stretching, you can easily exceed 3 times the weight of the vehicle. usually not that extreme when trying to pull someone out, but it does get up there in numbers. if im doing math right..... which isnt always the case...... velocity times weight is force? (hope thats right) so 7000 pounds moving at 20mph equals 140,000lbs? now the kinetic energy ropes are designed to stretch and not take all that at once and since the stuck vehicle (in this case) requires less than that to be pulled out, shouldnt be an issue. but i have always been one to think to go big all the time. get more than what you need, so in case you need more, you have it
