billyhondajet
Where did you get all of these tech docs? Is it a manual you can buy?Wasn't easy, but I found it for you. Cam Caps:
Phasers:
Hope it helps. Good luck!
Phasers:
So, what finally happened to the engine?
So is yours still gas or did you diesel swap it?I know his was not installed yet, but I run a 7.3L set up in my 6.2L. It has so much stupid torque I had a hard time getting into boost. It is an easy build to do. Just takes some custom pistons. If anyone is interested in the same I can get you in touch with the gentleman who came up with the custom pistons. On aside note you will find out really quickly if our overdrive drum has issues. Also the 6R80 is not the hard to rebuild, must make sure you get the calipers and dial indicators needed.
