Rear SCAB Door Rattle. Can't figure it out
FP Forged
FP Forged
Justin
Reno, NV
Try something for me. Just barely close the rear door and the front door so neither of them are shut tight and go for a short ride. I had a similar sound that was caused by the rear door panel rubbing on the trim when fully closed.
That worked. What did you do to fix it?
Shoulda bought a SCREW...
Sometimes I wish I did. But then I remember a SCREW is just a regular F150 crew cab with fenders and suspension :ROFLJest: . All jokes aside I like that the SCAB is one of the only extra cab short bed trucks produced. And the SCAB just barely fits in my garage.
BIRDMAN
Birdministrator
Boston
In my case, the plastic door sill wasn't snapped in all the way at the back and was rubbing on the bottom of the door panel. I figured this out by first doing what you did then I found a small wear spot where it was rubbing. See if you can find where 2 plastic panels might be rubbing together.
FP Forged
FP Forged
Justin
Reno, NV
Didn't see any wear on the plastic. Tried closing the back door tight and leaving the front door not all the way closed and there is no rattle/click. So it is something involving the where the front door latches/seals to the back door. Now I just have to pin point where it's coming from and whats actually making the noise.
