rear main seal leaking again after Ford warranty repair - could the oil pan be part of the problem?
IamNomad
Estes Park Colorado
At 14,000 miles an inspection during an oil change on the road at a Ford dealership showed oil leaking in the skid plate area. They told me they thought the oil pan might be leaking and when I got back home to Colorado to have my local dealer look at it.
At 17,000 miles my closest Ford dealership in Loveland, CO (1 hour away) determined that the rear main seal was what was actually leaking. They had the truck for over a week and supposedly had to take out the transmission twice to finally fix the leak, under warranty of course.
Now at 21,000 I needed another oil change so I alerted my local trusted independent to check for any further leakage. He found some oil building up inside the skid plate as well as dripping off the area near where the drain plug is. It only used 1/2 quart over 4000 miles so it is a very slow leak.
I now must leave on another long road trip to Florida and will have to have the truck looked at and repaired in St. Petersburg. Not sure I trust the Loveland dealer to fix this problem anyhow.
Has anyone else seen this problem with rear main seals?
Is it possible it could be a leaky oil pan instead?
Any advice would be appreciated on how to get this problem handled once and for all.
It's not just getting the repair done under warranty that matters, I also need reliable transportation during a series of very long road trips I must make in the next few months. Obviously I am checking my oil levels regularly.
Thanks in advance.
greatone99
ma
Thanks in advance.
u sure it's not sloppy oil changes, the raptors r a pain to do. without making even a little mess. if u don'ts drop the skid plates almost in possible to not get oil on plates when changing oil filter
EricM
OHIO
One messy one I could believe but not three in a row.
Why? It didn't get any easier to change the oil after the first one.
I always take my skid plates off to change oil. Then you can inspect the engine for things like front and rear main seal leaks, in addtion to not making a mess.
I
IamNomad
Estes Park Colorado
I can't completely rule what you say out but two different Ford dealerships and an independent I have used for years would have all had to make sloppy oil changes.
greatone99
ma
Let me rephrase sloppy , I myself have a hard time doing it without making a mess , and I’m beyond an **** , if they don’t take the plates off , ur making a mess . If u take them off , it’s a regular oil change , a small potential for a mess . Almost no place takes the plates off. Pretty easy to determine take all the plates off yourself , clean , put cardboard under it over night , check for spots
Mad Zeus
Florida
My experience with ford dealerships in Florida hasn’t been good the truck came back with more problems than it went in with . Not just bad service but mind numbing insanity bad . Two very simple repairs turned into 6weeks multiple returns a rental and flatbed tow . Not to mention trying to charge parts not belonging to the truck .
