Rear cab mounts broke?
  • Start date
Guest
Ok on a more serious note can you rig up some sort of pin to hold them back in place?
Might be able to, I was thinking the same thing. Might make it stronger than those factory pin that sheared off.
Guest
Is there something you have not broken??? LOL
What, like an antenna? Or antenna's? Or antenna mounts? What are you trying to say sick one?
Just for the record, I haven't broken the rubber floor mats. Well shit, I did that too, slammed it on the ground to knock the crap out and it shattered those plastic clips that holds the driver side in. Ok, I haven't broken the.....shit I don't know, guess I break everything....
Guest
Wrecking Ball Rick.
Thought ball was NUT or NUTS....
---------- Post added at 10:05 PM ---------- Previous post was at 09:53 PM ----------
Wow, did not realize that your could go back and actually modify the words in someone else's post being a moderator and make it look like they did it. That's powerful stuff there if a mod ever went rogue....
