Rattling in low gear under light -mild load
Meat2022
Alabama
check heat shields on your exhaust , sometimes band clamp will break , also that you skid plates are tight , tap around with a rubber mallet if you can recreate the noise.
Had the same issue on my gen1 ....clamp on heat shield broke. Rattle drove me crazy!!! Thought it was iwe....nope...easy fix. Hope it's simple for you too
Sekah
California
I think it’s just a normal rattle unfortunately. It bugged me for the life of the vehicle but it never impacted the performance or use, and it never seemed to get worse / louder. Just stayed consistent under low end load. I had the dealer try to look into it and like expected they didn’t find anything.
Thank you so much. that gives me a peace of mind!
raptortrav001
Oceanside, CA
Search for waste gate rattle on this forum. There was a write up about putting springs from Lowe’s on them to create tension and stop the rattle. Springs were in stock at my local store and it works like a dream! 5 min install.
