I had this done and it did not fix it. I notice when i press down on the roundish black plastic thing in the bottom left corner it goes away. it seems to be coming from that specificallyThere is a TSB for it.
Kit here:
Kit Rear Window Repair ML3Z-16423B99-A | OEM Parts Online
Kit Rear Window Repair ML3Z-16423B99-Aford.oempartsonline.com
It did it on my 23 as well. I just bought the kit and did it myself. it took a few minutes and fixed the issue.
I recently had this done also and the rear window is not any better, maybe even worse. I noticed some more obvious and worse rattle sounds coming from the rear window when the truck is cold before the interior heats up. That rattle is different than before the tsb fix. At the same time my bed cover makes a ton of noise, kind of a tin rattling noise. I have the Retrax Pro. So between the Retrax and the window I get a tin rattle like noise and a chirping like noise.I had this done and it did not fix it. I notice when i press down on the roundish black plastic thing in the bottom left corner it goes away. it seems to be coming from that specifically
