Raptor R intake?
TX NPmedic
Since the studs didn’t line up, I took them off, allowing the whole filter/shield assembly to slide rearward, giving clearance to the coolant tube. Mine sits flat on the factory rubber grommets and has decent room to adjust before tightening down the connection to the engine. It appears the slots in the shield need more travel to accommodate this issue and still use the billet studs.
WMRaptor
Massachusetts
I run the AFE sounds good but S&B might have more whine. I have a S&B setup from my old 23 if anyone is interested hit me up.
RoNiN Raptor
Colorado
Good looking! What's your feedback on it?
More whine than stock?
Are IAT's any lower?
Truck feel any stronger?
Install was pretty straight forward and easy.
The whine isn’t any louder or more noticeable which was slightly disappointing.
Temps I can’t say yet since we’ve been pretty cold lately and I do my driving early morning and evening.
The truck seems to accelerate a bit smoother, it likes its anticipating the acceleration into the shift point better. If that makes sense…
RoNiN Raptor
Colorado
Just an additional follow up,
IAT this morning,
Ambient air temp was 16-26 degrees by the time I got into work approximately 50 mile drive from the prairie through Denver.
IAT ranged from 91-98 degrees with temps typically dropping a couple degrees after heavy throttle input.
Torchy
Nevada
Thanks for the feedback.
Not too many with these and I've been wanting to know that info. Sounds like real world info too. So not much on white or IAT's. Not shocked though.
I'm seeing similar IAT's with higher ambients so might just be an engine bay temp thing.
RoNiN Raptor
Colorado
Yesterday on my way home through stop and go traffic and ambient air temps around 50 degrees, I hovered around 95-98 degrees. Than once I hit the open highway and got up to speed I dropped back down to 91-93 degrees.
xgardx
CLE OH
It has a louder SC whine with the clear lid and front plug out…. But then you might has similar or higher IATs than stock.
Also it’s almost as loud if you just take the stock airbox lid off, just a different t note.
Also you can pop the sticky noise dampening aluminum plates off the top of the SC lid. ( the triangles and square under the red/ black decorative plate) they’re easy to get off with a small screw driver or pry bar, held on by double sided rubber tape.
