Raptor Embroidery's Anzo Headlight Build
TexasBob
Dallas, TX
I saw that. Coming together slowly. Tires are in, got Discount to order Method NVs for $150 ea, and should be ordering bedsides tomorrow. Full-race intercooler comes in tomorrow or Friday and then the little things that need to be line-xed. Would love to replicate your retrofit so take lots of pics because I'm a dummy when it comes to projectors and doodads, lol
Btw, that IG account is just for the truck. My other one is tanksniper1.
Raptor Embroidery
Raptor Embroidery
aka <b><font color='darkorange'>Raptor_Al_41</font
Scottsboro, Alabama
Okayyyyyy. Here we go.
Just pulled the raptor into the garage. Went down to auto zone first and picked up Sylvania silverstars. Stock headlights are gonna suck but they are temporary. Atleast I have my Rigid DOT approved dually fog lights to run in the meantime!
60% moisture. No standing water At least. Drivers side
Passenger side is still going strong
Marked the stock projector cut offs on the wall. It won't be exact but it'll help during the retrofit.
Also put tape in front of my tires to mark where I need to park the truck during each test fit. Its going to be hard to keep these intact pulling in and out of the garage daily.
I forgot to call anzo to order 2 new lenses. One has a crack and the other has permanent bug remains from a trip to Michigan where I didn't have access to a car wash.
Anzo will be called tomorrow!
Tonight -
-remove headlights, reinstall factory halogen headlights
-place headlights in oven, open them up
-build a parts list and order projectors, led strips needed for build
-draw up a few diagrams for projector mounting brackets
-draw up wiring diagrams for bi-xenon harness
-take measurements on the halogen high beam reflectors to see if I can mount a rigid dually in there
-etc. etc. (things always get more complicated when I start into a project)
Stick around fellas
Sent from my VS985 4G using Tapatalk
Raptor Embroidery
Raptor Embroidery
Scottsboro, Alabama
Lookie what I found digging through my crawl space.
This brings me to an important point during this retrofit that I thought I might share. Back before I knew much about lighting, I ordered an HID pnp kit. What a mistake. I kept getting high beamed and I didn't know why.
HID bulbs should only be installed in HID projector housings. There are even projectors out there that are only designed to run halogen bulbs, not xenon.
Running xenon bulbs in a halogen reflector housing (like the ones that come stock on a raptor) will blind oncoming drivers. This is due to the fact that xenon bulbs have a way more intense output. A projector has a shield and lenses that direct the light into a flat pattern that does not spill into oncoming drivers eyes. Halogen reflector headlights do the same thing kinda. They don't cut off the light very well and a little of it will spill into oncoming driver's eyes. Most have a reflector and a bulb shield. The shield covers the bare bulb and helps direct most of the light onto the road. Installing a xenon bulb can actually disrupt the placement of the filament under the cover. If the arc of the xenon bulb is back, the light can Hit the top of the reflector and simulate a high beam, which is basically the same intensity as an Offroad light. Even if the arc is under the bulb cover, it can still create light spill that will blind other drivers.
Another point is that HIDs will disrupt the intended pattern of light that the headlight was originally intended to produce. Placing an HID bulb into a halogen reflector will create hot spots and dark spots in your pattern of light as well, decreasing your visibility.
If you're going to upgrade your headlights, do it right.
Sorry about the long post, seeing these bulbs in the stock housings reminded me.
Raptor Embroidery
Raptor Embroidery
Scottsboro, Alabama
Okay! Stock headlights are back in. I already miss the anzos. Don't worry though, they'll be back in soon!
Oem halogen reflector headlight output
Raptor Embroidery
Raptor Embroidery
Scottsboro, Alabama
Headlights are apart!!
Instructions to bake open :
1. Clean the headlight lenses. I used GooGone - Window Cleaner - and finished off with alcohol to remove everything and leave a very dry surface. (you don't want to bake any sediment on the lenses. It will be there for good)
2. Remove as many parts as possible. Bulbs, wires, rubber grommets, etc.
3. Preheat oven at 275°
4. Unclip the clips around the perimeter of the headlight. (don't touch the lenses)
5. Put on mechanic's gloves and place in oven. They will expand a tiny bit so allow for it (mine did a little bit)
6. After 7 minutes, remove headlight from oven.
7. Start prying the lens off of the housing with a flat head. Don't worry if you bend the housing, once you heat it up after you're done on the inside, you'll be able to bend the plastic back.
8. The black housing piece (below) is attached to the lens. It will come with the lens when you pull it off. Remove 4 Phillips screws and the the bezel comes off
Inside of the headlight
Once the lens is off and the bezel out of the way, you can remove the mount for the projector and high beam. On the bottom of the piece, you'll see two pop tabs. Click those in and lift up. On the top, the adjustment screw basically sits against the back of the housing. Turn it, it adjusts the piece. Slide the mount towards the outside of the headlight.
The tabs are the white pieces
Grab like this and slide this way
Once that's out, you'll see the projector is held in by 3 screws. It will be very easy to mount a mini H1 lucky for me.
Basically, the Mini H1 has a threaded mounting shaft on the back. Since this projector mounts with 3 screws, all I'll have to do is make a mount with 3 legs and a base in the middle with a hole in the middle. Simple simple simple. I just have to make sure it's the same depth. There's not much room around the projector lens up front. I'd recommend getting it closer to the front of the headlight to add a bit more side lighting.
Anyway, here is the bracket I'm talking about. Notice the lines going up to the flat piece. Those run from the projector mounting screws to a piece where the Mini H1 will screw in. No cutting required!!
Next - U bars. Making them switchback. I was hoping they would be clear all the way through but they've actually got white paint or something on the back. Hopefully I'm able to remove it with a polishing wheel on my dremel. The stock leds are on top of the U bars behind the bezel.
See the circuit boards? There are 2 per bar.
Here's what the U bar looks like taken out of the headlight.
Here's the paint I need to remove. The new led strips will mount under the U bars. Hopefully they'll be twice as bright. The stock ones in the headlights are already very bright.
Where the LED strips are going. Behind these U bars.
Stock LED chips for illuminating the U bars
Time to start ordering parts!
Raptor Embroidery
Raptor Embroidery
Scottsboro, Alabama
So, right before I ordered the 18" white/Amber switchback LED strips for illuminating the Halos, I found these bad boys:
These are White/Amber switchback LED chips. They come with the controller.
These will replace these chips that are built into the anzo headlight. All I have to do is build a mount bracket.
What I have ordered
-Morimoto Mini H1 7.0 projectors
-Morimoto 6500k H1 HID bulbs
-White/Amber switchback LED chips for U-Bars
Still to be ordered
- RGB demon eyes for projectors
-80mm housing caps
-butyl glue
-rubber wire pass through grommets
-4 x 3" Amber strips to use as side markers
-1/4" conduit to make for a clean looking install
-aluminum tape
Painting
-I'm having a close friend of mine that's in the body work business paint the bezels ebony black to match my factory paint
-tint the Amber side marker
-re-paint the back of the halos white to assure no light is spilled out of the halos
Laser engraving
-etch raptor logo into projector lenses
Brackets
I've got another friend that is in the metal working business. He's an excellent welder/fabricator.
-Brackets for Mini H1 projectors
-Braces to keep the plastic mounts from cracking
-brackets for the 8 switchback leds for the halos
-brackets to mount the ballasts, RGB controller, Switchback controller and LED driver for the high beams
Wiring (oh lord)
-build bi-xenon harness
-wire all 4 switchback LED chips together (per headlight)
-wire 2 3" led strips together and power from the side marker bulb socket (pics of that to come)
-run all wires out of headlight. When all said and done, I should have about 9 wires to run out of the headlight. Not too bad. Low beam, high beam, ground, switchback positive/negative, and Red, green, blue and ground for the RGB demon eyes.
Stay tuned....
Raptor Embroidery
Raptor Embroidery
Scottsboro, Alabama
Looks like I'll be buying another set of lights after I get the internals done. I don't get it though? They sell their lights that they design and have manufactured and they can't get just lenses for their lights? Someone that knows more about legality of manufacturing needs to chime in....
Raptor Embroidery
Raptor Embroidery
Scottsboro, Alabama
