Raptor Air Oil Catch Can
SVT_4X4
Linden, MI
UPR Products Dual Breathers
I have about 800 miles on my UPR Products dual install. This is on a ProCharged Raptor and I mounted these on the firewall. It worked out well because I removed the cowl plastic covers and actually bolted these in from that area. Instead of using the plastic fittings that came with these, I ordered aluminum AN fittings and push on rubber breather hose. I then welded two bungs on the air inlet tube to the Supercharger and attached each breather to these. So far no oil in passenger side, and good amount of oil / mix in drivers side, see below pictures. I kept hearing people say you did not need the passenger side, but wanted to make sure this engine could breath, but it looks like it may have not been needed. But it is on, and will stay there.
Dv8tor
Detroit, MI
No it's the other way around. I'm NA for now. Passenger side is collecting but drivers side is dry. Thats weird that its totally opposite for Forced Induction. O well. I'm no engineer. I think it's good insurance to have these catch cans. I'm going to keep my dual setup plumbed just in case.
NJStangersJonathan
North Jersey
any idea where I can get the moroso catch can? I checked their website and it wasn't exactly easy to navigate. I checked Summit Racing and UPR Products but nothing.
Scrap man
Ohio
you can get the moroso from summit racing that's where I got mine from it only took about 4 days till I received it. it was easy to install and I think the fact that it has its own stand is a big plus over the other systems out I can post some pics later if you would like
MTF
Celebration, Florida
Did you have to modify the bracket to fit around the wiring harness?
I had to cut an inch off the side of the bracket, Moroso is looking into it but this might be just 2010 specific.
